martintw
Newbie level 5
Hello,
I am designing a magneto resistive encoder. For the magneto resistive sensor I am using KMXP5000 sensor, for further signal processing I took IC-TW8 interpolator. The problem I have is the noise in power supply, the noise is only there when IC-TW8 interpolation IC is running, if I reset it the noise disappears. I included the image from oscilloscope, the purple channel is the ripple and noise measurement from power supply. I am measuring same noise if I put probe to GND plane, can someone tell me why ? I included image of PCB top plane so you can see how I designed circuit. I have split ground plane and only power supply trace is passing from digital to analog side of circuit. Is there a way of measuring where the noise come from or how one diagnose such circuit ?
Thanks for any help.
