Did you try to find the information on your own? (I doubt it.)
Where? At the place where it is produced: the PCB manufacturer.
A simple search "pcb copper thickness" gives many, many, many results.
Often you find: 1oz Cu per square foot, 1.0oz. = .0014″ (35 microns) , 35um, 0.035mm
Other thickness for sure is possible...
Klaus
Sounds like Rame means trace width rather than trace thickness (copper weight)...
What is the standard trace thickness used for multi layered,multi signal board.?
If they don't charge extra for 150u, then chances are that means they are overcharging for the wider feature specs :razz:Sounds like Rame means trace width rather than trace thickness (copper weight).
These days, I get 150 µ or 125 µ from most PCB manufacturers at no extra costs. Thus I would rate it as industry standard technology. High volume production might choose wider traces to increase reliability and production yield if technically possible.
Complex PCBs often use 100 µ trace width, real high density possibly 70 µ.
True, in my experience via size will be as much as a limiter as width/spacing limitations. A good fabhouse will allow down to 8mil holes with 18mil annular ring diameter with no extra cost.One other slight detail might be preferred hole sizes.
Trace thickness=copper thickness, 1oz is most customers choice, if the boards isn't power PCB...
Current density through the track will have no effect on magnetic radiation, only on voltage drop and track heating.If in a layout the trace width is reduced let's say from 20 mil to 5 mil. Does it radiate more ? which also means more cross talk ?
