Minimum peak detector
Kunna
Newbie level 5
Newbie level 5
I need to detect the minimum peak of a sawtooth signal and output it. Does anyone have an idea how i could do that?
EDIT:Maybe i should clarify, using CMOS circuit design.
Interesting little waveform :) Is there anything else you can tell us about when this "little" sawtooth occurs? i.e. is it completely at random? I can not see how we can detect the difference between the most negative excursions of the big saw tooth and the little sawtooth.
Frank
Frank
I have converted Pulse width into an amplitude(that is what u see there, the max always occurs on the falling edge of that PWM). So getting the minimum peak will give me the smallest pulse width. I've thought about use a CMOS latch storing those peaks and then using a comperator to find out what the smallest one is. But a latch is digital, and if my +VCC is 3.3v and -VCC the GND ( so binary 1=3.3v and 0=0v) and i want to store lets say 1.3v won't the latch converge that value to a binary 0, which equals to 0v. Meaning i have lost my input.
Hi.
Since you seem to compare it against later "waves", you need to have a function that remember many peaks and that can compare them. Ie, you need some microcontroller.
Hi.
cant use microcontoller its IC.
Seems like a though question...
Yes, but how do you make the circuit to "know" the next pulse?
Anyway, you have to make at least two storage circuits (sample and hold), probably more.
The falling edge of the pulse (that is used for reset of the integrator) can be used for storing its voltage into a sample-and-hold circuit, only if the new value is lower than the old. I.e., there is a comparator that enables or not the S&H. (There should be a small delay before the integrator reset.)
Regards
Z
I would have expected the sampling waveform to look different with at least some dead time between samples. I don't see it in your waveform. Am I missing something?
Yeah u are right, there should be dead time in between. The drawing i made is just bad :S
