Thanks @microlab.
according to me the atmel AT89c2051 controller will do(in terms of cost).
you may found many cheaper controllers which may not be available in india(i think you are an indian).but if the quantity is so much, you will get good pricing from the vendors.
India it is
. A very quick price check at Element14 and couple of other distributor shows the price to be still close to about $2. Could you / someone experienced with current volume pricing tell me if it can be brought down to $1 level ? If so, at what kind of volume !! My earlier search had shown me some PIC's available at $0.70 range for about 10units. Of course, I didn't get around to do a apples-to-apples comparison...
any way you have to do the hardware interfacing for the control unit.(you said you are going to control 1.5KW motor).you have to interface 1 transmitter and 1 receiver to the controller because the modules are available only for 1 purpose.the range will be about 30 meters if you connect the good antenna and of line of sight.
for better range you can use tranceiver modules from TI. but they are costlier compare to the ASK modules.
Doing a quick search earlier had actually found 2 different type of such transceivers -- one claiming to be able to do 30mtrs and another upto 100mtrs. Is this TI module mentioned do 100mts ?
here also the quantity does matters.
Any idea on what could be the volume price (just to have an estimate) ? My idea is to fit the entire bill-of-material(right?) within a certain range, so this query.
if you don't want the data back from the slave, there could be some other options.
Could you plz elaborate as to what other options are possible ?
my question is if all the outputs are working on 230VAC, why you need a battery back up?
Summer is around the corner, and many places will start having erratic 2-4 hours power cuts. I thought this let's me know if power is there or not ! Although on second thoughts I am beginning to question it's value. Maybe have this kind of sensor specifically for the power presence check with a tx on module !
Reading a bit more on Edaboard, I am seeing lot of discussion around Powerline communication for similar applications. Looks very interesting ! However, I am guessing that the system goes dead during power-failures. Given the resistance (I'm assuming it to be quite high) of normal household electrical wiring, I guess attempting comm. on something like 12V battery power would be impossible !
---------- Post added at 22:54 ---------- Previous post was at 22:36 ----------
Thanks @wp100.
Well your idea is sound, but as for manufacturing such a system think you will find there are many similar systems on the market though perhaps with not as much feedback, if turning on a fridge needs any ?
Look at systems like X10 developed for doing just this kind of thing.
Commercialising the idea is not my primary objective
... satisfaction of doing something useful is! Of course, if commercialisation helps a cause, all the more better.
I did run into X10 and bunch of others... just after posting this. Looks very interesting, but as you mention I saw that it doesn't seem to have any feedback.
Turning fridge on/off doesn't need feedback for sure, however turning on/off an old AC, that has fixed thermostat(right?) might be interesting. if in the same unit I can add a temperature sensor, it can help me turn it into a climate control solution as well. something, I think I can't do with X10... I might be wrong, haven't spent enough time reading about it.
Have used those ASK modules but you need to use an encoding method (typically Manchester) otherwise your signals will be lost in the mass of other signals at that frequency.
Okay. Do I need to do the manchester encoding in software? And, don't I need something to uniquely identify each such modules from the central controller and back ? Would it be something like a uniqueId hardcoded in program memory ? Or is there some other way ?
You might find Bluetooth a better method.
Would love to do that... in fact, that was my first thought. Would've let me control the switch directly using my mobile, but 2 worries crept in.
1. Wouldn't that require a much higher capability MCU, and add significantly onto the overall BOM cost ?
2. Bluetooth range seems to be pretty limited. Solution seems to be Zigbee, but zigbee apparently needs software stack, and thus overall BOM becomes expensive.
3. Both of those were taking the complexity beyond my reach
... it already seem to be fairly complex.
