Mini compressor based on refrigerator aggregate
B
BlackMamba
Newbie level 1
Project by: misiek84LG
Source here
"I present a very simple compressor based on a refrigerator aggregate. It was planned to pump various tyres. Compressor should be portable and protect the tyres from the oil in the compressed air.
Metal ampulla of aggregate has been cut at weld junction and all old tubes have been removed. In new positions a grommets (10 mm screws) for connecting hoses nave been placed; internally they are connected to the compressor: output with a metal tube originally mounted in aggregate; input – with a rubber tube. To the metal ampulla a holders were welded to allow wrenching, junction was packed with a paper seal and a silicone.
In upper cover there is additional opening with a 1.5mm screw for oil filling or discharging. Opening allows the same pressure as ambient, and that’s why oil will not be pushed out through leakages.
Compressor may be transported in almost every position and oil will not leak."
