The milling machine was made of aluminum sheet, what provides the ease of processing the components.
Parameters:
- working area: 450x500x150
- the maximum feed speed: 1500mm/min
- spindle mechanical power: 400W
- processed materials: plastics, wood, aluminum, copper
- drawings and model made in Invertor
- control software: Mach3
- drawings made in programs: b2g, Inventor, ARTCam, ImgToGcode
x axis
- supported shafts dia 14
- trapezoidal propeller dia 18
- table made of 12mm aluminum sheet
y axis
- steel shafts dia 16
- trapezoidal propeller dia 14
z axis
- made of aluminum sheet on two shafts dia 16
Electronics:
- 3x stepper motor 3Nm/4A
- 3x driver 4,2A with microstep
- main board
- pulse power supply 36V/10A
- automatics
The device was tested in milling and cutting aluminum, engraving, cutting pannels for housings and milling PCBs.
Link to original thread (useful attachment) – Mini Frezarka CNC z aluminium
