danny davis
Banned
How do you use milliohm resistors to do current sense or act like a fuse?
I see them used on transistor emitter to ground and FET source to ground to do current sensing or to act like a fuse, but for what reason?
Where else would you use milliohm resistor?
In a class AB amplifier , where do they put the milliohm resistors mostly? they either use the milliohm resistor to do current sensing or to act like a fuse
Do you know any other circuits that uses milliohm resistors like a fuse or current sensing?
