jit_singh_tara
Full Member level 6
- Joined
- Dec 22, 2006
- Messages
- 325
- Helped
- 9
- Reputation
- 18
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- Delhi , India
- Activity points
- 4,295
Hello friends ,
I need to build an application where :
I need to access my mcu pins data on/off , adc data on a website which i could access from anywhere .....
So far this is my setup :
What i am doing is that connecting enc28j60 module to my hardware and connecting the lan cable to its connector on one end , other end connected to my router .
Similarly 2nd lan cable connected between my laptop and router .
Using the mikroc compiler to run the example project with mcu changed , i m using pic16f887 .
So far i am just trying to run the example project but it is not connecting .i.e
running on 8Mhz internal oscillator , SPI MODE.
I read the ip address of my laptop connected to router it showed 192.168.1.260 .
I changed the ip address in the c code to this value .
When i tried to open the website using this address it is not connecting .
Another point is that i dnt know what to do with mac address ,how to identify my enc28j60 mac address .
I want to know where am i wrong , or what should i do to work in right direction .
Not much aware about tcp/ip settings , networking etc.....
Please help how to open the webpage connecting to my hardware via enc28j60.
The code is as follows :
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 // duplex config flags #define Spi_Ethernet_HALFDUPLEX 0x00 // half duplex #define Spi_Ethernet_FULLDUPLEX 0x01 // full duplex // mE ehternet NIC pinout sfr sbit SPI_Ethernet_Rst at RC0_bit; sfr sbit SPI_Ethernet_CS at RC1_bit; sfr sbit SPI_Ethernet_Rst_Direction at TRISC0_bit; sfr sbit SPI_Ethernet_CS_Direction at TRISC1_bit; // end ethernet NIC definitions typedef struct { unsigned canCloseTCP: 1; // flag which closes TCP socket (not relevant to UDP) unsigned isBroadcast: 1; // flag which denotes that the IP package has been received via subnet broadcast address (not used for PIC16 family) } TEthPktFlags; /************************************************************ * ROM constant strings */ const unsigned char httpHeader[] = "HTTP/1.1 200 OK\nContent-type: " ; // HTTP header const unsigned char httpMimeTypeHTML[] = "text/html\n\n" ; // HTML MIME type const unsigned char httpMimeTypeScript[] = "text/plain\n\n" ; // TEXT MIME type unsigned char httpMethod[] = "GET /"; /* * web page, splited into 2 parts : * when coming short of ROM, fragmented data is handled more efficiently by linker * * this HTML page calls the boards to get its status, and builds itself with javascript */ //************************************************************************* // Change the IP address of the page to be refreshed const char *indexPageHEAD = "<meta http-equiv='refresh' content='10;url=http://192.168.1.260/'>\ <HTML><HEAD></HEAD><BODY>\ <h1>PIC 16F887 (8MHz) + ENC28J60 Mini Web Server,<p>avec MikroC PRO v5.6.1</h1>\ <p><a href="http://olivier.fournet.free.fr/e.html">NOTICE</a><p>\ <p><a href=/>Reload</a><p>\ <script src=/s></script>"; const char *indexPageBODY = "<table><tr><td valign=top><table border=1 style='font-size:20px; font-family: terminal;'>\ <tr><th colspan=2>ADC</th></tr>\ <tr><td>AN2</td><td><script>document.write(AN2);</script></td></tr>\ <tr><td>AN3</td><td><script>document.write(AN3);</script></td></tr>\ </table></td><td><table border=1 style='font-size:20px; font-family: terminal;'>\ <tr><th colspan=2>PORTB (IN) : <script>document.write(PORTB);</script></th></tr>\ <script>\ var str,i;\ str='';\ for(i=0;i<8;i++)\ {\ str+='<tr><td bgcolor=#cccccc>BUTTON #'+i+'</td>';\ if(PORTB&(1<<i))\ {str+='<td bgcolor=green>ON';}\ else\ {str+='<td bgcolor=red>OFF';}\ str+='</td></tr>';}\ document.write(str);\ </script>"; const char *indexPageBODY2 = "</table></td><td>\ <table border=1 style='font-size:20px; font-family: terminal;'>\ <tr><th colspan=3>PORTD (OUT) : <script>document.write(PORTD);</script></th></tr>\ <script>\ var str,i;\ str='';\ for(i=0;i<8;i++)\ {\ str+='<tr><td bgcolor=#cccccc>LED #'+i+'</td>';\ if(PORTD&(1<<i))\ {\ str+='<td bgcolor=yellow>ON';\ }\ else\ {\ str+='<td bgcolor=#999999>OFF';\ }\ str+='</td></tr>';}\ document.write(str);\ </script>\ </table></td></tr></table>\ <p>This is HTTP request #<script>document.write(REQ)</script><p>\ </BODY></HTML>"; //************************************************************************* /*********************************** * RAM variables */ unsigned char myMacAddr[6] = {0x00, 0x14, 0xA5, 0x76, 0x19, 0x3f}; // my MAC address unsigned char myIpAddr[4] = {192,168,1,260}; // my IP address unsigned char getRequest[15]; // HTTP request buffer unsigned char get_Request, digit_getRequest, etat_interrupteur; unsigned char dyna[30]; // buffer for dynamic response unsigned long httpCounter = 0; // counter of HTTP requests /******************************************* * functions */ /* * put the constant string pointed to by s to the ENC transmit buffer. */ /*unsigned int putConstString(const char *s) { unsigned int ctr = 0 ; while(*s) { Spi_Ethernet_putByte(*s++) ; ctr++ ; } return(ctr) ; }*/ /* * it will be much faster to use library Spi_Ethernet_putConstString routine * instead of putConstString routine above. However, the code will be a little * bit bigger. User should choose between size and speed and pick the implementation that * suites him best. If you choose to go with the putConstString definition above * the #define line below should be commented out. * */ #define putConstString SPI_Ethernet_putConstString /* * put the string pointed to by s to the ENC transmit buffer */ /*unsigned int putString(char *s) { unsigned int ctr = 0 ; while(*s) { Spi_Ethernet_putByte(*s++) ; ctr++ ; } return(ctr) ; }*/ /* * it will be much faster to use library Spi_Ethernet_putString routine * instead of putString routine above. However, the code will be a little * bit bigger. User should choose between size and speed and pick the implementation that * suites him best. If you choose to go with the putString definition above * the #define line below should be commented out. * */ #define putString SPI_Ethernet_putString /* * this function is called by the library * the user accesses to the HTTP request by successive calls to Spi_Ethernet_getByte() * the user puts data in the transmit buffer by successive calls to Spi_Ethernet_putByte() * the function must return the length in bytes of the HTTP reply, or 0 if nothing to transmit * * if you don't need to reply to HTTP requests, * just define this function with a return(0) as single statement * */ unsigned int SPI_Ethernet_UserTCP(unsigned char *remoteHost, unsigned int remotePort, unsigned int localPort, unsigned int reqLength, TEthPktFlags *flags) { unsigned int len = 0 ; // my reply length unsigned int i ; // general purpose integer // should we close tcp socket after response is sent? // library closes tcp socket by default if canClose flag is not reset here // flags->canClose = 0; // 0 - do not close socket // otherwise - close socket if(localPort != 80) { // I listen only to web request on port 80 return(0) ; } // get 10 first bytes only of the request, the rest does not matter here for(i = 0 ; i < 10 ; i++) { getRequest[i] = SPI_Ethernet_getByte() ; } getRequest[i] = 0 ; if(memcmp(getRequest, httpMethod, 5)) { // only GET method is supported here return(0) ; } httpCounter++ ; // one more request done get_Request = getRequest[5]; // s , d if(get_Request == 's') // utiliser pour <script src=/s></script> { // if request path name starts with s, store dynamic data in transmit buffer // the text string replied by this request can be interpreted as javascript statements // by browsers len = putConstString(httpHeader); // HTTP header len += putConstString(httpMimeTypeScript); // with text MIME type // add AN2 value to reply IntToStr(ADC_Read(2), dyna); len += putConstString("var AN2="); len += putString(dyna); len += putConstString(";"); // add AN3 value to reply IntToStr(ADC_Read(3), dyna); len += putConstString("var AN3="); len += putString(dyna); len += putConstString(";"); // add PORTB value (buttons) to reply len += putConstString("var PORTB="); IntToStr(PORTB, dyna); len += putString(dyna); len += putConstString(";"); // add PORTD value (LEDs) to reply len += putConstString("var PORTD="); IntToStr(PORTD, dyna); len += putString(dyna); len += putConstString(";"); // add HTTP requests counter to reply IntToStr(httpCounter, dyna); len += putConstString("var REQ="); len += putString(dyna); len += putConstString(";"); } else { // if(get_Request == 'd') // Commande PORTD { if( isdigit(getRequest[6]) ) { digit_getRequest = getRequest[6] - '0'; // numéro de port 0 à 7 if( getRequest[7] == 'o' ) // Contact Ouvert (OFF) etat_interrupteur = 0; if( getRequest[7] == 'f' ) // Contact Fermer (ON) etat_interrupteur = 1; switch(digit_getRequest) { case 0: PORTD.B0 = etat_interrupteur; break; case 1: PORTD.B1 = etat_interrupteur; break; case 2: PORTD.B2 = etat_interrupteur; break; case 3: PORTD.B3 = etat_interrupteur; break; case 4: PORTD.B4 = etat_interrupteur; break; case 5: PORTD.B5 = etat_interrupteur; break; case 6: PORTD.B6 = etat_interrupteur; break; case 7: PORTD.B7 = etat_interrupteur; break; } } } // } if(len == 0) { // what do to by default len = putConstString(httpHeader); // HTTP header len += putConstString(httpMimeTypeHTML); // with HTML MIME type len += putConstString(indexPageHEAD); // HTML page first part len += putConstString(indexPageBODY); // HTML page second part len += putConstString(indexPageBODY2); // HTML page second part } return(len) ; // return to the library with the number of bytes to transmit } /* * this function is called by the library * the user accesses to the UDP request by successive calls to Spi_Ethernet_getByte() * the user puts data in the transmit buffer by successive calls to Spi_Ethernet_putByte() * the function must return the length in bytes of the UDP reply, or 0 if nothing to transmit * * if you don't need to reply to UDP requests, * just define this function with a return(0) as single statement * */ unsigned int SPI_Ethernet_UserUDP(unsigned char *remoteHost, unsigned int remotePort, unsigned int destPort, unsigned int reqLength, TEthPktFlags *flags) { return 0; // back to the library with the length of the UDP reply } /* * main entry */ void main() { //ANSEL = 0x0C ; // AN2 and AN3 convertors will be used //C1ON_bit = 0; // Disable comparators //C2ON_bit = 0; PORTA = 0 ; TRISA = 0xff ; // set PORTA as input for ADC //ANSELH = 0; // Configure other AN pins as digital I/O PORTB = 0 ; TRISB = 0xff ; // set PORTB as input for buttons PORTD = 0 ; TRISD = 0 ; // set PORTD as output OSCCON =0b01110001;delay_ms(100); OPTION_REG = 0b10000000; INTCON.GIE = 1; INTCON.INTE = 1; /* * starts ENC28J60 with : * reset bit on RC0 * CS bit on RC1 * my MAC & IP address * full duplex */ SPI1_Init(); SPI_Ethernet_Init(myMacAddr, myIpAddr, Spi_Ethernet_FULLDUPLEX) ; while(1) { // do forever /* * if necessary, test the return value to get error code */ SPI_Ethernet_doPacket() ; // process incoming Ethernet packets /* * add your stuff here if needed * Spi_Ethernet_doPacket() must be called as often as possible * otherwise packets could be lost */ } }
