MikroC code to receive SMS
tritech
Newbie level 6
Newbie level 6
PIC : PIC18F4520
PICPLC16v6 Development Board from Mikroelectronika
GSM Modem : Quectel M95
Can receive SMS by Hyperterminal
+CMTI: "SM",28 telling New SMS arrived, index in SIM Memory 28
AT+CMGR=28 AT command to Read SMS whose index is 28
+CMGR: "REC UNREAD","+6597329728","","2013/08/15 15:17:56+32"
Sms recd
OK
Need to implement this read part in MikroC programming. Any help
Pick up a simple code of serial interfacing through which u can Tx n Rx with interrupt.
sent "+CMTI: "SM",28\r\n "
and wait for receive interrupt flag to be high den read the Rx buffer,
compare that buffer with desired string using "strcmp"
n return whtever u want :)
Use uart library in MIKROC to do this task. In help you will find every thing you need.
