Mikro c : varialble decleration problem
dashkil
Member level 2
i have some problem in this code;
this one is correct. but having problem as mentioned below:
char text[]="kkkkk";
void main()
    ADCON1=0x06;
    TRISA=0xFF;
    TRISB=0;
    PORTA=0;
    PORTB=0;
     while(1){
     char z;
                       if(PORTA.F0==1)
                        for(z=0;z<5;z++)
                        PORTB=text[z];
                               else
problems:
1) when i declare char text[] in the void main() it shows error; it shows no error when declare outside the void main as global variable.
2) Again declaring char z within void main or outside shows error; but no error when decelerated within while loop.
i need explanation about this kind of problem.
Which compiler are you using? Which version? Can you post the screenshot of error message.
You need a semicolon at the end of the first statement.
Try this code. If it gives error again then reinstall your compiler and check.
void main()
     char z;
     ADCON1=0x06;
     TRISA=0xFF;
     TRISB=0x00;
     PORTA=0x00;
     PORTB=0x00;
     while(1){
              if(PORTA.F0==1)
                  for(z=0;z<5;z++)
                        PORTB=text[z];
              else
Why are you trying to assign string to PORT?
Declare both at the beginning of the main loop - before everything else. Declarations must be done at the beginning. You'll see that it's all okay, then.
//char text[]="kkkkk";
void main()
    char z;
    ADCON1=0x06;
    TRISA=0xFF;
    TRISB=0;
    PORTA=0;
    PORTB=0;
     while(1){
                       if(PORTA.F0==1)
                        for(z=0;z<5;z++)
                        PORTB=text[z];
                               else
Hope this helps.
Tahmid.
