ryanelectronicengineering
Newbie
Hi all, I am in the process of making changes to some assembly code to work with a different PIC uC due to parts shortage, We are going from 16F628 to 16F1826 and when I compile it gives error(s) at these lines:
and
I get Error at:
Found label after column 1. (CLJA) & Found label after column 1. (CLJB)
I have never seen an instruction called CLJA & CLJB
Can anyone shed some light on these two instructions? Code was written by someone that is no longer with company and I see no macro's attached to ASM. I'm using MPLAB X
Thank you -Ryan
;TEMP3 HOLDS THE NUMBER OF BITS OF ALARMS
CLJA TEMP3,1,MULTIPLE_ALARMS ;CLEAR THE ALARM COUNT (LEAVE THE FLASHING LED ON), CONSTANT BEEP
;NOW SET THE ALARM COUNT BASED ON WHICH ALARM IS SET
;IF MULTIPLE ALARMS, ONLY THE AUX LED FLASHES (IN TIME WITH THE FLASH COUNTER)
and
;INITIALIZE MEMORY HERE ALL MEMORY (020h-07Fh)
MOVLF 020h,FSR
INIT_L CLRF INDF
INCF FSR,F
CLJB FSR,080h,INIT_L
;DONE WITH ZERO MEMORY
I get Error at:
Thank you -Ryan
