monolothics
Junior Member level 3
Hi, all
I have a problem here,,
How can i design a High Pass Filter with given phase shift??
Thank you
Thank you
Hi, all
Thank you
When the input frequency is above the filter's pole frequency, phase leads.
When it is below the pole frequency, phase lags.
Phase lags?
First order highpass: Phase goes from +90 to zero deg
Second order: Phase goes from +180 to zero deg.
Please reformulate your question. To me it is not clear what you really want to know.
What i wanto to know is, how can i design a HPF or LPF with an output of certain phase shift???
for example, i want a HPF that can give a 22,5 degree phase shift, how can i do that??
........ It caused me to think of the phase shift as leading and lagging, whereas it was only phase leading, in the range you stated.
What means "certain phase shift"? A certain value at one single frequency or a certain phase function?
