microwave antenna design
vytux
Newbie level 3
Newbie level 3
microwave antenna size
Hi, I want to make antenna operating at 15GHz for my radio relay system. Thanks a lot for any help
microwave antenna types picture
can you give me more information ? For example what you need ? What type of antenna you can use ? - omnidirectional, directional, size, bandwith.....
You can use horn, conical horn, reflector antenna, microstrip antenna, dipol.... and so on...
odu (outdoor unit) for antenna
I need a directional microwave antenna, the size shoud be about 1feet.
In that image in the left side is ODU unit with antenna and in the right side it is Out Door Unit, that I have.
manufacturer of odu for microwave antenna
So you need feed for reflector antenna ? I see on the left picture antenna, probably reflector antenna.
If you have circular waveguide (from your ODU unit), you can use some type of back feed (rear feed, hat-feed) for reflector antenna, for example follow this
but you need 3D simulation software, the best is CST MWS.
    vytux
producer of outdoor unit for microwave antenna
thanks very much for help
designing outdoor unit for antenna
You have not more question? :)
determining microwave antenna size
now I'm working with CST MWS, later I think I will have some questions
