Microvolts to frequency
Navaneeth.A.Gowda
We are doing project on EEG signals using OpenBCI device, output of signals are in microvolts how can we convert them to Frequency ?
Python as language?
Amplifier and VFC / VCO all are hardware, no need for software.
Klaus
Some questions -
1) What is the range of signal, min to max, of signal you want to convert to frequency ?
2) For the range in 1) above what is range of frequencies you want ?
3) What is resolution of signal you want, both in 1) and 2) ?
4) Do you want a sine, square, encoded frequency signal out of solution ?
5) Do you need to filter signal path ? LPF, BPF, HPF, Band Reject (to get rid of power line freq 50/60 Hz)....?
Regards, Dana.
So you don't want to convert them to frequency, you want to measure their frequency?
Brian.
Yes, i have values from -15000 micro volts to 15000 micro volts EEG data. i want these values in frequencies ranging from 0 to 100 hz. What are the steps i need to follow? Could you help me, in what order to follow the steps
Some questions -
Regards, Dana.
I have values from -15000 micro volts to 15000 micro volts EEG data. I want these values in frequencies ranging from 0 to 100 hz bcz brain signals are measured in terms of Hertz, What are the steps i need to follow? Could you help me, in what order to follow the steps
The required procedure is calculating the power spectrum, respectively magnitude of fourier transform. As far as I see, it's already included in OpenBCI software tools. Did you read the manual?
See FFT Plot below:
See FFT Plot below:
The data I have is completely raw, this raw file contains only values in microvolts
