yefj
Advanced Member level 5
Hello,I want to add a VIA fence to improve the signal of the microstrip shown below. I know that the distance between vias (brown arrow) is lambda/20.
1.what via diameter to use?
2.What the the vertical distance (blue arrow) between the VIAS?
3.If i will put a field monitor on the VIA fence how can i see from the electric field that the VIA fense is working well? Thanks.
