leaps
Member level 2
patch antenna array
halo i have designed an four patch array. single suspended patch had gain 8db than i designed two patch array usuing the same suspednded antenna design gain was 10 db than i designed four patch array using coperate feed network the gain is 12.8 db. now i would like to ask for opinion is this increase in gain correct a teacher told me it is not that high :S.now just to check i designed 4*2 array the gain is 15.7 is this gain low im a bit down after these results and confused can you gove me your suggestion's ??
