sahar20
Member level 1
I have a microstrip design, with a number of stubs, spurlines and vias, which occasionally produces a gain of over 100dB at a single frequency. Since there are no devices in the circuit, this is obviously a singularity of some sort in the software. The circuit is all on a single layer, vias only to ground, ports with extensions, and when built it appears to be otherwise accurate. Is this common, what causes it and how can I avoid it?
