mando88eg
Newbie level 5
Hello Everybody,
My Name is Abdelmoniem Mowafak El-Assar, Student at the AAST, Last year, and this subject is my Grad Project.
Actually um having some troubles that i wanna share with u.
1st I've just finished my program for Designing Microstrip Antenna knowing only f ( the desired frequency) & (er & height) for the dielectric material using matlab. with 2 solutions till now (Rectangular Patch and Circular Patch).
that was the results :
for the Circular :
units are in cm , u should multiply by 10 to make it mm
at f=3.5 Ghz, er=4.65 and h=1.5 mm
The radius of the circluar patch :
a =1.0670 cm = 10.67 mm ( in Hfss)
ae =1.1652 cm= 11.652 mm ( the effective )
The Substrate & ground :
Lg =1.9670 but we will take lg= 6.5 cm = 65 mm (in Hfss) ; because Lfeedline + 2*a is larger than the Lg, is that reliable >???
Wg =1.9670 but we will take wg=2.5 cm = 25 mm (in Hfss) ; because Wfeedline + 2*a is larger than the Lg, is that reliable >???
The Feed Line
Lf =4.2000 cm = 42 mm (in Hfss)
Wf =0.2751 cm= 2.751 mm (in Hfss)
L: length
W:width
a:radius
h:hight
fperating frequency
when i finish my program isa, I'm gonna make it programmed to be like an incredible accurate calculator.
Hope Help
Thanks
for the Circular :
The Feed Line
L: length
W:width
a:radius
h:hight
fperating frequency
Hope Help
Thanks
