paula_popa
Newbie level 1
Please if someone can help me with the microstrip array antenna at 30 GHz. I have made 4 microstrip antennas and I fed them in parallel, but the radiation pattern for the directivity and gain does not display anything...what could be the reason? Is it because I didn't use the antenna array setup configuration? I didn't use that setting because you can not design the feed network..please someone help me...I'm trying do this for 2 days already....
