T
treez
Hello,
We are using the SAM3N00B microcontroller's DAC output to provide a voltage.
The DAC's output voltage goes to an RC filter which is 1K and 100p.
Page 720 of the SAM3N00B datasheet says that the max load capacitance for the DAC can be no more than 50pF.
Since our 100p is not directly connected to the DAC pin, but is after the 1K resistor, will we thus be allright using the 100p capacitor?
Also, page 720 of the SAM3N00B datasheet says that the minimum resistor load for the DAC output is 5K....does this mean that any resistor that shunts to ground from the DAC pin must be greater than 5K?
SAM3N00B DATASHEET:
http://www.atmel.com/Images/doc11011.pdf
SAM3N00B DATASHEET:
