Microcontroller USB with VC++
ARagab
Newbie level 5
Newbie level 5
hallo people,
I want to control an USB port connected to a Microcontroller using simple GUI VisualC program(Read, Write, Open, Close ... etc). Does anyone know how to use the API of the USB in WindowsXP with VC to do that?
And if there is any other way to do this function, then what is it?
Please answer in deep Details, because I've never done something like that before.
Thanks in advance
Try
h**tp://www.beyondlogic.org/
They have a lot of info on usb.
i'll tell you how to use the C or C++ to control the USB port ( or any port generally).
It is easy by C & C++ since you many orders control ports , This orders are :
INP(8-bits) , INPW(16-bits) , OUTP , OUTW .
If you have the C / C++ version with help you'll find an example for the all these
orders in the help .Only you have to know the number of the port on your PC .
In my PC the USB port have the number : E800 - E81F . Also you will have to connect
an interface circuit between your PC and The µC to convert from serial port Logic ( -15 - +15 )V
to TTL Logic ( 0 - +5) V . an simple circuit called Max232 with 5 capacitors will
do the job . If you want to know how to connect the Max232 go to this link :
https://www.qsl.net/sv1bsx/max232/max232.html
Hope this help you .
If you have any problem please send me .
