Dear All I found this from MPLAB help
Project Wizard - Add Files
Step 4: Add Any Existing Files to Your Project - If you already have files that you would like to add to the new project, select them now:
Choose the file(s) to add. Click on a file name to select that file. <Ctrl> + Click to select more than one file. Click Add>> to list file(s) to be added to the new project.
Click the icon next to the file name to cycle through available modes (see below).
To remove file(s) from the list, click on the file name(s) to select and then click Remove.
Most projects will require the addition of a linker script file. Consult your language tool documentation for details.
Click Next to continue.
File-Addition Modes
The MPLAB IDE project wizard now supports file-addition modes. Modes affect whether the project references the file by a relative or absolute path, which impacts project portability and the behavior of "Save Project As".
Relative paths typically improve project portability, where as absolute paths tend to make projects less portable. "Save Project As" using relative paths causes a file to be copied when a project is saved to a new directory. "Save Project As" using absolute paths merely adjusts the file's path when a project is saved to a new directory.
[A] Auto - Allow MPLAB IDE to determine whether the file's path should be relative or absolute based upon the file's location. If the project directory contains the file, the reference is a relative path. Otherwise, the reference is an absolute path.
User - Reference the file with a relative path. This is the preferred way to add files created specifically for a project.
System - Reference the file with an absolute path. There are cases when this mode is useful, but these paths often require correction when a project is moved from one system to another.
[C] Copy - Copy a file to the project directory and add a relative path to the copied file.
Optionally, edit the file name to rename the local copy of the file. This mode provides a convenient way to incorporate linker scripts and template source files into a project without introducing an absolute path.
---------- Post added at 23:13 ---------- Previous post was at 23:04 ----------
