leorickings
Junior Member level 1
Hi, I'm working on a project to control valves, one at 240Vac and another at 24Vdc. The system is controlled with a PIC microcontroller. I have been searching for info on interfacing microcontrollers to the industry world, but found literally nothing. Why isn't there anything about this? How do the industry achieve high power control with logic level controllers?
I have been trying the simplest solution - relays. Out of so many products, I found a relay with 5Vdc coil, which I can drive with a transistor from the microcontroller, with 230Vac / 24Vdc contact. But this component is so rare that none of the suppliers are willing to supply unless in a massive quantity.
Optocouplers and TRIACS are super rare too, especially the ones matching my requirements....
Please help, I believe there is not only me facing this problem
