Microcontroller-based: Electric fan switching- relay or triac?
crankler
Junior Member level 2
I have a project in which i will control the speed of the electric fan (220Vac, 60W, 5A max.) through the microcontroller automatically depending on the temperature. I was planning to replace the fan's switch with either a relay or triac. Min. time interval between switchings is 10seconds.
Which do you think is better suited for the application: RELAY or TRIAC? why?
Thanks..
Is it controlling the Speed or just switch off/on?
control the speed With a Relay?? not a good choice
Obviously it should be the Triac.
This electric fan has a switch for speed control (1,2,3). I can replace the rotary switch with relays or triacs, one for each speed level. Forget about phase control with triac, etc. All i need to do is switching.
For only switching relay is ok. I still suggest triac as it is a solid-state solution, no mechanical parts.
Hope this helps.
Tahmid.
I think i've read something like triac consumes more power than relay.. i was also wondering how to turn the triac on and off with a microcontroller. Would it be like just give enough voltage/current to the gate turn it on, and to turn it off, just remove the gate voltage... or the gate voltage should be in sync with the 60Hz line voltage (zero crossing detector) to turn it on, and additional commutation circuit to turn it off?
Take a look at this:
In this circuit, giving one to the transistor turns on the triac:
I hope you understand why.
Hope this helps.
Tahmid.
Thanks for the schematic. How about turning it off, will it turn off if i give zero to the transistor?
And the microcontroller is dc and the triac is ac so we cannot just connect their grounds.
Please check the above triac circuit for the correct connection of triac terminals and power supply. It's supposed to give a nice cloud of smoke when powered.
To make it work correctly, MT1 has to be connected to neutral and the positive DC supply.
P.S.:
It's no problem, if you don't mind the microcontroller circuit being connected to the mains supply. Because you can't rely on neutral being actually at safe ground potential, you have to regard the complete circuit as "live" with respective safe insulation.
Why? This is properly shown. Microchip has also shown such a connection in AN958, fig 5:
Plus I've found such circuits in commercial IR dimmers as well. They all work fine.
Hope this helps.
Tahmid.
Look sharp! In your previous schematic, you have connected neutral to 5V and live to MT1. So +/-300 V peak are applied over Q1, R6 and triac gate. The Microchip circuit is correct of course, because live connects to +5 and MT1.
P.S.: As minor point, I would strictly avoid to exchange pins MT1 and MT2 in a circuit symbol. The numbers may be overlooked, and then you get the triac wrongly connected.
Yes, but the circuit I've shown is taken from a fellow member's circuit (circuit had error, fixed that, didn't see that, sorry) and I've found this configuration in a commercial IR dimmer circuit.
And I've even tried by reversing live and neutral on that circuit and there's no "smoke" or anything as such. I've even built my IR fan speed controller on the very board and everything works as desired.
Whatever you tell, be very sure that it does not work. But I'm basically satisfied, if we can agree, that the Microchip circuit is working correctly and should be suggested.
P.S.: Sometimes schematics don't represent the actual circuit. Someone may have corrected them silently when assembling the circuit.
Why not give it a try and tell us the result? I have the circuit working, maybe you could give it a try.
---------- Post added at 18:10 ---------- Previous post was at 18:03 ----------
There was no correction as the said circuit was on PCB and I traced the circuit from there and then made by circuit with that.
Yes, the circuit provided by Microchip is fine.
Well, this was not there in your acual question.
For this application , just use the relays and switch it on and done, and do not worry about the reliability etc etc, I have seen relays working for years without any fuss.
Though triacs are the better option, you need to understand the functionality, circutry etc etc and finally you will end up not making anything.
@ FvM,
Hi, here are the PCBs of the circuit I was talking about and it's working fine. You should give the circuit a try and see what happens.
Tahmid.
Unfortunately, I can't decode the wiring from the PCB bottom. Do you have a sharp foto or a copy of the artwork?
The proper camera is out of order. I'll upload a much clearer photo by day after tomorrow. By the time, you can try the circuit and find out if it's working or not.
---------- Post added at 22:27 ---------- Previous post was at 22:12 ----------
I scanned this using my scanner as the camera is out of order:
---------- Post added at 22:42 ---------- Previous post was at 22:27 ----------
O, I see what you mean. The diagram had an error. Sorry for the confusion.
Good, everything clear now, the photo and the circuit.
Whoa,,didn't expect there would be arguments.. by the way, thanks to Tahmid & FvM.. i thought MT1 and MT2 are interchangeable. Didn't expect that Line can be connected to +5v safely.
So it would work without a zero-crossing detector?
And if i give enough voltage/current to the gate, the triac will turn off, and if i remove the gate voltage/current, the triac will instantly turn off?
I just thought that SCRs are more difficult to turn off, requiring a commutation circuit and it might also be the same with the TRIAC...?
For on/off switching of inductive loads, zero crossing detectors are generally unwanted in my view. For gavanically isolated control, a MOC302x opto triac is the most simple solution.
Ignoring zero crossings mean, turn the output on or off at will. The triac (or SCR) will immediately turn on, but turn off delayed after the next load current zero crossing (which is not exactly identical to voltage zero crossing with inductive loads). A RC snubber would be needed at least with MOC302x to prevent dV/dt self triggering, but doesn't harm with triacs in general.
