Microchip's released Application Maestro
Ace-X
Advanced Member level 2
Germany
microchip application maestro
The Microchip Application Maestro™ Software is a freestanding software tool, allowing you to configure and incorporate a range of pre-written firmware modules into your application.
You can select one or more modules and configure the parameters. Then the Maestro software generates code that can be incorporated into your application project using MPLAB® Integrated Development Environment or any compatible development environment. The Application Maestro™ Software tool is designed to work with all PIC® MCUs.
Currently available modules:
RTC general-purpose library module
ADCPol Library Module (Polled)
CAN Bootloader
CAN driver with prioritized transmit buffer
I2C® Master Library Module (Polled)
I2C® Slave Library Module (Interrupt-driven)
SPI™ Master Library Module (Polled)
Interrupt based UART library module
