Microchip (Pic) based braille language project
hum20005
hi everyone .
I have been given a project which involes the use of microchip (PIC) . i need to display alphabet on lcd display ( its like a seven segment display).
i need to build the hardware as well as the soft ware. the project is Braille to alphabet. so i need to convert the braille input to the display. there are six switches for input.
however, i do know how to write a pic program but the problem is that how can i start this specifice program. i'm having trouble writing this special source code using Assembly language.
can someone give some guidance?( pls provide source code if possible)
thanks
Dear friend,
Actually your project is simple one. Here i attach a program for LCD display and also lcd commands do it yourself and make necessary changes.
  • lcd.txt
  • LCD Commands and Instruction set.doc
