dr pepper
Advanced Member level 1
Using an arduino, a 6v bicycle bottle dynamo and a 2S lipo battery I want to build a mini battery backed wind generator.
I have a couple of questions on charging the batts, the dynamo (magneto) acts like a current source, so if I was to rectify its o/p and feed that to a buck boost switching reg like a Lm2576 configured to draw 500ma from the supply using a sense resistor, and its o/p goes to charging the batteries via a Schottky (the reg's feedback would be setup so its o/p voltage wouldnt go over 8.4v the safe max for the cells).
As I understand it a balance charger connects a resistor across a cell that is close to 4.2v, this sounds inefficient and wouldnt work so well if the battery was loaded as well as charging. Is there a better way I can balance charge a 2S lipo, or should I make the thing 2P and boost the o/p voltage with another smps chip?
