d123
Advanced Member level 5
I'm trying to learn a little about active filters. Chose specs of high Q, passband centred at ~10.5kHz, gain of 10 (for no special reason).
Before getting onto the MFB I copied, some questions would be:
For flat passband and sharp stopband transition and minimum parts count, which is the most appropriate topology?
Not Tschebyshev, clearly; Butterworth seem far too slow in stopband and Bessel seem worse than Butterworth in that respect. Or are these assumptions incorrect?
MFB have drawback of inverting (from what I've learnt so far) - does that mean an allpass is required after MFB to get in-phase output, and is that horrendous to put together for a person who still hasn't found a suitable explanation of how to implement "s" and "√-1" in formulas I see, nor how to assess phase response in AC transfer results?
I copied the MFB narrow bandpass from this pdf:
View attachment Band_Pass_Filters.pdf
This is the schematic and the results:
The resistor values are calculator-based results, not standard values, so as to see what to expect in an ideal world.
From the tiny graph, do the results, centred at 10.5kHz seem ~realistic and what one would hope to see? How far does a real implementation diverge from this, if it's possible to describe?
If the input signal is centred at 2V and rises/falls 0.5V, what kind of output voltage would I expect with a gain of 10, and how do I extrapolate this from the gain graph results, please?
I think I have quite a few more questions but I'll try not to be a pita. A problem I have is that I'm beginning to think a lot of the didactic material/app notes seem to show somewhat idealised/exaggerated response curves to help understand the premise more than the reality, maybe I'm wrong.
Thanks
Thanks
