can you give name of without pc , microcontroller based and FTDI baseHi,
* The PIC datasheet tells you which method (ports, pins, voltages, protocols....) the IC accepts.
* All programmers (PC based, arduino, dedicated programmer, anything else ...) need to keep on these methods.
So PIC side is clearly defined.
But programmer side variants are unlimited: With / without PC, PC with different OS, differnt software tools, FPGA based, microcontroller based, logic based, external USB periferal based (FTDI...) ...
countless.
Klaus
ok ......Hi,
All my above items are meant "with or without".
So: with / without FPGA, with / without microcontroller, with / without logic ICs, with / without USB.
Everything is possible, many solutions are already available..
Please exactly define what you want. In terms of hardware, in terms of functionality,... supported devices, supported programming method, operation methods, data storage, display or not, keys with which functiinality...
Otherwise you just keep us busy with guessing.
Your "half line posts" give not much information...
Klaus
