Methods of generating sine wave using VHDL
1nandha
Junior Member level 1
What are the different methods that can be used to generate a sine wave using VHDL other than CORDIC?
Re: Sine wave using VHDL
DDS (effectively a more sophisticated LUT)
To find out CORDIC algoritm. It is the best way to generate Sin and Cos to use basic operations -shift,addition,not.
implement the taylors formula for sine function in vhdl.
Absolutely use DDS IP Core.. It's pretty easy to run and get data.
It has also run-time frequency change option.
