[SOLVED] metal detector schematic disponible
N
Neron
Newbie level 1
metal detector schematics
I have stored 2 kind of metal detector based on microcontroller. I build both and i am sur it is good. Have a look at filemanager: Neron/metal_detector.
If someone have other schematics i am interrest.
hi all
here is a good design
for a multicpu multicoil multiband scanning metal detector
uses a hardware scope to target and has audio
no code avalible so is for development
Uploaded file: **broken link removed**
metal detector dsn
Thanks the borg for your send. But i have a little probleme to read the file metal.dsn you sent. Could you help me ?
Thanks
Neron
metal detector with lcd display schematic
yes
to view { and alter etc}
the dsn above
install proteus vsm
but for now
here is a windows metafile
{will open direct with most versions windows or photshop or paint shop pro etc}
in an archive to save space as it was 1 mb or so
now a few hundered k
so download unpack and view
metal.dsn
yes
the dsn above
install proteus vsm
but for now
stuart pi 16c84 metal detector
Ok thanks a lot the borg. I had a look to the schematic. It is a quite complex schematic. I was wondering if the 2 schematics oscilloscope represent the emitter and receiver coils ?
If yes, is it possible to have their caractéristics.
I was also wondering why is there two lcd display ?
And the last question (but i think you have already answer) is there a possibility to obtain the source code for the microcontroller?
I know, there are a lot of questions.
metal detector shematic
    V
to anyone with an interest
here are the coils dimetion and a picture
here is the coil calc i used
the dimentions are this
center coil 44T .51 7 cm sides equal sided triangle
second coil out is
round 10 cm dia 33 T .71
third
is triangle equal sides so 25 T .51 mm
fourth is round
22cm dia 27T .71mm
so all coils are around 1.11111 henry
using 1 as the relative permabilitie of copper
but i think the coils arent so crytical
1}becouse a pi detector isnt a resonace coils
for rf
2} as the timming is full adjustable for all coils drive
so the same timmings as a gold pic or pic84 stuart design
but with space for coils to run like
1 2 3 4 or 2341 or just on one coil {best one for gold etc}
and also the lcd should give accurate readout of ground effect zero and metal type
while the scope part shaws a target
made of rings that get smaller in sequence with some dots missing
for target etc and to gather info
so is very very much development still too do
its rough but ready
coil design metal detector
sry forget to put the online calc
and here is a good theory site for metal detctor technique
again use bable fish altavista to get to your language
<font size=-1>[ This Message was edited by: THE BORG on 2001-12-13 18:29 ]</font>
top metal detector schematic
if you can send this rar file to me or give link to it.
THE BORG PLAESE..!
good metal dedector desing help...!
