AdvaRes
Hi members,
I need to measure the discharge time of a Latch. I used spectre to simulate the Latch. Simulation was done with the extracted parasitic parameters R and C in the latch. PLS consisted that the latch holds a 1 Logic (1Volt) and once this is done the input of the Latch and the clock signal are maintainted to 0 Logic (0 Volt). I set the simulation time to 10ms but it seems that the latch'output doesn't change. Even by extending the simulation time to 1 second the output of the latch remain the same at 1 Volt like if there is no leakage at all.
Do you have any Idea what causes that and why the Latch does not discharge.
