baby_1
Advanced Member level 1
Hello
i want to measure a AC voltage 300 volt and 50Hz with MCU ADC , as you know i can use transformer to isolate and decrease the input voltage(300 volt) and then rectifies it then measure by MCU , or can rectifies the input voltage and then decrease voltage with resistor divider network.
but i have these problem:
1-if i want to use transformer it use big size in my board but isolated it good for me
2-it i use the diode and resistor it has a small size but doesn't have any isolator
is there any way that isolate the input voltage and has a small size? IC available ?
