Ethan25
Junior Member level 3
I need some advice on how to collect data using mems microphone? should I collect them as .wav file and then use them for processing or should I collect the analog values and then use it for processing, i felt using .wav file would make the file size big so i though collecting the analog values storing them in a csv and then using MATLAB I can process it.
Which is a better way ?
