memory allocation of volatile,const
bhadmanathan
Junior Member level 1
A typical memory representation of C program consists of following sections.
1. Text segment (program)
2. Initialized data segment (static/global)
3. Uninitialized data segment (static/global)
4. Stack (local variables,function calls)
5. Heap (dynamic allocation)
out of these five, where
local volatile variables
global volatile variables
local const variables
global const variables
string literals
will get stored...?
Only Text segment is ROM or every region has its ROM..?
And also...
In which time , memory for a variable will get allocated ? compile time or run time ?
I heard that only syntax errors are checked during compile time and memory will be allocated during run time. I dont understand it clearly. If it is wrong please explain me clearly..
Thanks in advance
Notice that you posted the question in PC programming rather than microcontrollers forum. In case of PC programs, the code is compiled for execution in RAM, it won't be able to run from ROM.
Generally, many answers depend on the runtime environment and compiler details.
The quoted memory layout is more typical for PC and RAM based embedded OS targets than ROM based microcontrollers. It would be reasonable to specify a target system when answering the questions.
To answer some general questions in advance.
The volatile qualifier is not particularly related to memory allocation. It's controlling the access to variable objects.
The const keyword primarly specifies that an object can't be modified at run time. Some compilers automatically move const objects to ROM by default, but the feasibility depends on the hardware architecture.
