-- megafunction wizard: %ALTERA_MULT_ADD v16.0% -- GENERATION: XML -- multiplier_adde
shaiko
Advanced Member level 5
Hello,
I created an ALTERA_MULT_ADD IP using Quartus Prime 16.0
And this is the VHDL output file I got:
-- GENERATION: XML
-- multiplier_adder.vhd
-- Generated using ACDS version 16.0 211
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity multiplier_adder is
	port (
		result  : out std_logic_vector(31 downto 0);                    --  result.result
		dataa_0 : in  std_logic_vector(15 downto 0) := (others => '0'); -- dataa_0.dataa_0
		datab_0 : in  std_logic_vector(15 downto 0) := (others => '0'); -- datab_0.datab_0
		chainin : in  std_logic_vector(31 downto 0) := (others => '0')  -- chainin.chainin
end entity multiplier_adder;
architecture rtl of multiplier_adder is
	component multiplier_adder_0002 is
		port (
			dataa_0 : in  std_logic_vector(15 downto 0) := (others => 'X'); -- dataa_0
			datab_0 : in  std_logic_vector(15 downto 0) := (others => 'X'); -- datab_0
			chainin : in  std_logic_vector(31 downto 0) := (others => 'X')  -- chainin
	end component multiplier_adder_0002;
begin
	multiplier_adder_inst : component multiplier_adder_0002
		port map (
			result  => result,  --  result.result
			dataa_0 => dataa_0, -- dataa_0.dataa_0
			datab_0 => datab_0, -- datab_0.datab_0
			chainin => chainin  -- chainin.chainin
end architecture rtl; -- of multiplier_adder
-- Retrieval info: <?xml version="1.0"?>
--	Generated by Altera MegaWizard Launcher Utility version 1.0
--	THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
--	Copyright (C) 1991-2016 Altera Corporation
--	Any megafunction design, and related net list (encrypted or decrypted),
--	support information, device programming or simulation file, and any other
--	associated documentation or information provided by Altera or a partner
--	under Altera's Megafunction Partnership Program may be used only to
--	program PLD devices (but not masked PLD devices) from Altera.  Any other
--	use of such megafunction design, net list, support information, device
--	programming or simulation file, or any other related documentation or
--	information is prohibited for any other purpose, including, but not
--	limited to modification, reverse engineering, de-compiling, or use with
--	any other silicon devices, unless such use is explicitly licensed under
--	a separate agreement with Altera or a megafunction partner.  Title to
--	the intellectual property, including patents, copyrights, trademarks,
--	trade secrets, or maskworks, embodied in any such megafunction design,
--	net list, support information, device programming or simulation file, or
--	any other related documentation or information provided by Altera or a
--	megafunction partner, remains with Altera, the megafunction partner, or
--	their respective licensors.  No other licenses, including any licenses
--	needed under any third party's intellectual property, are provided herein.
-- Retrieval info: <instance entity-name="altera_mult_add" version="16.0" >
-- Retrieval info: 	<generic name="number_of_multipliers" value="1" />
-- Retrieval info: 	<generic name="width_a" value="16" />
-- Retrieval info: 	<generic name="width_b" value="16" />
-- Retrieval info: 	<generic name="width_result" value="32" />
-- Retrieval info: 	<generic name="gui_4th_asynchronous_clear" value="false" />
-- Retrieval info: 	<generic name="gui_associated_clock_enable" value="false" />
-- Retrieval info: 	<generic name="gui_output_register" value="false" />
-- Retrieval info: 	<generic name="gui_output_register_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_output_register_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_output_register_sclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_multiplier1_direction" value="ADD" />
-- Retrieval info: 	<generic name="gui_addnsub_multiplier_register1" value="false" />
-- Retrieval info: 	<generic name="gui_addnsub_multiplier_register1_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_addnsub_multiplier_aclr1" value="NONE" />
-- Retrieval info: 	<generic name="gui_addnsub_multiplier_sclr1" value="NONE" />
-- Retrieval info: 	<generic name="gui_multiplier3_direction" value="ADD" />
-- Retrieval info: 	<generic name="gui_addnsub_multiplier_register3" value="false" />
-- Retrieval info: 	<generic name="gui_addnsub_multiplier_register3_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_addnsub_multiplier_aclr3" value="NONE" />
-- Retrieval info: 	<generic name="gui_addnsub_multiplier_sclr3" value="NONE" />
-- Retrieval info: 	<generic name="gui_use_subnadd" value="false" />
-- Retrieval info: 	<generic name="gui_representation_a" value="UNSIGNED" />
-- Retrieval info: 	<generic name="gui_register_signa" value="false" />
-- Retrieval info: 	<generic name="gui_register_signa_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_register_signa_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_register_signa_sclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_representation_b" value="UNSIGNED" />
-- Retrieval info: 	<generic name="gui_register_signb" value="false" />
-- Retrieval info: 	<generic name="gui_register_signb_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_register_signb_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_register_signb_sclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_input_register_a" value="false" />
-- Retrieval info: 	<generic name="gui_input_register_a_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_input_register_a_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_input_register_a_sclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_input_register_b" value="false" />
-- Retrieval info: 	<generic name="gui_input_register_b_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_input_register_b_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_input_register_b_sclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_multiplier_a_input" value="Multiplier input" />
-- Retrieval info: 	<generic name="gui_scanouta_register" value="false" />
-- Retrieval info: 	<generic name="gui_scanouta_register_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_scanouta_register_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_scanouta_register_sclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_multiplier_b_input" value="Multiplier input" />
-- Retrieval info: 	<generic name="gui_multiplier_register" value="false" />
-- Retrieval info: 	<generic name="gui_multiplier_register_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_multiplier_register_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_multiplier_register_sclr" value="NONE" />
-- Retrieval info: 	<generic name="preadder_mode" value="SIMPLE" />
-- Retrieval info: 	<generic name="gui_preadder_direction" value="ADD" />
-- Retrieval info: 	<generic name="width_c" value="16" />
-- Retrieval info: 	<generic name="gui_datac_input_register" value="false" />
-- Retrieval info: 	<generic name="gui_datac_input_register_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_datac_input_register_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_datac_input_register_sclr" value="NONE" />
-- Retrieval info: 	<generic name="width_coef" value="18" />
-- Retrieval info: 	<generic name="gui_coef_register" value="false" />
-- Retrieval info: 	<generic name="gui_coef_register_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_coef_register_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_coef_register_sclr" value="NONE" />
-- Retrieval info: 	<generic name="coef0_0" value="0" />
-- Retrieval info: 	<generic name="coef0_1" value="0" />
-- Retrieval info: 	<generic name="coef0_2" value="0" />
-- Retrieval info: 	<generic name="coef0_3" value="0" />
-- Retrieval info: 	<generic name="coef0_4" value="0" />
-- Retrieval info: 	<generic name="coef0_5" value="0" />
-- Retrieval info: 	<generic name="coef0_6" value="0" />
-- Retrieval info: 	<generic name="coef0_7" value="0" />
-- Retrieval info: 	<generic name="coef1_0" value="0" />
-- Retrieval info: 	<generic name="coef1_1" value="0" />
-- Retrieval info: 	<generic name="coef1_2" value="0" />
-- Retrieval info: 	<generic name="coef1_3" value="0" />
-- Retrieval info: 	<generic name="coef1_4" value="0" />
-- Retrieval info: 	<generic name="coef1_5" value="0" />
-- Retrieval info: 	<generic name="coef1_6" value="0" />
-- Retrieval info: 	<generic name="coef1_7" value="0" />
-- Retrieval info: 	<generic name="coef2_0" value="0" />
-- Retrieval info: 	<generic name="coef2_1" value="0" />
-- Retrieval info: 	<generic name="coef2_2" value="0" />
-- Retrieval info: 	<generic name="coef2_3" value="0" />
-- Retrieval info: 	<generic name="coef2_4" value="0" />
-- Retrieval info: 	<generic name="coef2_5" value="0" />
-- Retrieval info: 	<generic name="coef2_6" value="0" />
-- Retrieval info: 	<generic name="coef2_7" value="0" />
-- Retrieval info: 	<generic name="coef3_0" value="0" />
-- Retrieval info: 	<generic name="coef3_1" value="0" />
-- Retrieval info: 	<generic name="coef3_2" value="0" />
-- Retrieval info: 	<generic name="coef3_3" value="0" />
-- Retrieval info: 	<generic name="coef3_4" value="0" />
-- Retrieval info: 	<generic name="coef3_5" value="0" />
-- Retrieval info: 	<generic name="coef3_6" value="0" />
-- Retrieval info: 	<generic name="coef3_7" value="0" />
-- Retrieval info: 	<generic name="accumulator" value="NO" />
-- Retrieval info: 	<generic name="accum_direction" value="ADD" />
-- Retrieval info: 	<generic name="gui_ena_preload_const" value="false" />
-- Retrieval info: 	<generic name="gui_accumulate_port_select" value="0" />
-- Retrieval info: 	<generic name="loadconst_value" value="64" />
-- Retrieval info: 	<generic name="gui_accum_sload_register_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_accum_sload_register_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_accum_sload_register_sclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_double_accum" value="false" />
-- Retrieval info: 	<generic name="chainout_adder" value="YES" />
-- Retrieval info: 	<generic name="chainout_adder_direction" value="ADD" />
-- Retrieval info: 	<generic name="port_negate" value="PORT_UNUSED" />
-- Retrieval info: 	<generic name="negate_register" value="UNREGISTERED" />
-- Retrieval info: 	<generic name="negate_aclr" value="NONE" />
-- Retrieval info: 	<generic name="negate_sclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_systolic_delay" value="false" />
-- Retrieval info: 	<generic name="gui_systolic_delay_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_systolic_delay_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_systolic_delay_sclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_pipelining" value="0" />
-- Retrieval info: 	<generic name="latency" value="0" />
-- Retrieval info: 	<generic name="gui_input_latency_clock" value="CLOCK0" />
-- Retrieval info: 	<generic name="gui_input_latency_aclr" value="NONE" />
-- Retrieval info: 	<generic name="gui_input_latency_sclr" value="NONE" />
-- Retrieval info: 	<generic name="selected_device_family" value="Cyclone V" />
-- Retrieval info: 	<generic name="reg_autovec_sim" value="false" />
-- Retrieval info: </instance>
-- IPFS_FILES : multiplier_adder.vho
-- RELATED_FILES: multiplier_adder.vhd, multiplier_adder_0002.v
For some reason, when I try to simulate the IP using Modelsim (Altera Starter Addition) - I get the following warning:
Warning: (vsim-3473) Component instance "multiplier_adder_inst : multiplier_adder_0002" is not bound.
You need to find the entity and architecture source code for 'multiplier_adder_0002'.
Kevin Jennings
Reactions: shaiko
    shaiko
