yefj
Advanced Member level 5
Hello,i have a system of a oscilloscope and signal generator .I took the input and split it into two .
one side went straight to the scope while the other wen to an SMA connected PCB board.
I used a probe to measure the SMA central pin .
When i looked at the scope i saw that my probed amplitude differs the coax input amplitude although they got the same input signal.
I think its because the probe is 1Mohm and coax probe is 50Ohm.
i want to know to properly understand the result i got on the screen.
Suppuse my signal generator is 50 Ohm and i have 1M Ohm probe on the scope side.
1.What is the equivalent circuit being created between the generator and osciloscope ?
2.At what place on the "circuit" i see the measured scope data?
Thanks.
Thanks.
