Measuring scattered fields from the scene/object plane received by a receiver/waveguide
meshedmangoes
Newbie
I have an antenna array setup with radiation boundary in HFSS. The fields are scattered from the object plane, lying at a distance (parallel to the array plane). I want to measure these scattered fields. Is a simple waveguide (appropriate to cut-off frequency) is enough to measure the scattered fields from the object? I want to run the simulation with changing antenna parameters (changing transmitting fields) and observe the scattered fields (reflected from the scene) received at the waveguide or observation plane.
If you have any idea of setting up such a simulation, it would be very helpful, thank you.
