T
treez
Hello, we have switch mode, 2W, xenon flashlamps which run off 20VAC, 50Hz.
Here is the input current and voltage...............
(the input features a rectifier bridge, followed by a 47uF cap)
https://i50.tinypic.com/63wppe.jpg
input current = red
input voltage = green
....It flashes once every 800ms......so the voltage and current pattern that you see above, repeats endlessly.
How do i measure the rms input current?
A meter is no good because the readout is constantly changing.
Also , how do we measure the power consumption?
..The switching frequency is around 25KHz, and you can see that some of the switching current is drawn through the supply wires....since its not all filtered by the lamps input filter.
input current = red
