OK thanks, i measured at 100kHz because that is the switching frequency. (well, switching frequency is 150kHz but 100Khz is generally "near" the various switching frequencies that get used, and its nice to keep it the same each time)Capacitances are regularly measured at 1 kHz.
you know thatOK thanks, i measured at 100kHz because that is the switching frequency. (well, switching frequency is 150kHz
At one time it was just dissipation factor at 120 Hz and low f C, now mfg's rate the ripple current at low and high f and commercial Philips LCR meters I used 25 yrs ago also had options up to 1 MHzCapacitances are regularly measured at 1 kHz.
