carvinguy
method measure fet temp
Does anyone know of a good thermal probe for measuring FET temperature in a live circuit? I need to monitor FET case temperature in my full-bridge SMPS. I'm using a Fluke 80TK- the kind that connects to a DMM, but it's giving me erroneous readings when the circuit is running. It needs to physically make contact with the tab on the FET, but since the tab is not at ground potential and is switching at 100kHz, the reading is not accurate. I need some type of proble that is either non-contact, or is not effected by switching noise when in contact. I think thermal imaging would be a terrific solution, but WAY too costly for the application.
Thanks for any help or suggestions.
