Sounds easy.. surely just need a current sense resistor and stick your oscilloscope on it to measure the voltage across it? Or have I missed something?!
Alternatively, as far as I recall from an old experiment, Fluke 179s can measure voltage RMS to 20kHz with little error.. possibly that extends to the current ranges too. So you could do a calculation, based on the fact that you're using a square wave, not a sine wave.
Dear grizedale
Hi
It is pretty simple . as i understood your current is kind of square wave , right ? so if you use a low value series resistor , such as 0.1 ohm m you can measure the voltage across it , and then use this formula :
Iave=1/T integral over imax dt from zero up to ton .
Good luck
Goldsmith
What will be the problem if you calculate it by yourself ? it is a simple equation . the result of that will be : Imax*D.C that D.C is duty cycle . is that difficult ? of course not .
THE CIRCUIT IS VERY IRREGULAR, AND THE ON/OFF DUTY IS VERY IRREGULAR, so WE NEED TO MEASURE IT directly, we are thinking of an input current sense resistor, and filtering it heavily and feeding this voltage to a accurate meter
If it's irregular and not a square wave or sinewave, and you have no tool to measure it, why not grab a screenshot of the scope waveform across the sense resistor, and manually calculate the average current across the period of the waveform using pen and paper?
