measuring current through a bf981
neazoi
Advanced Member level 6
Greece
how to measure current flowing through a bf981 which is loaded with drain and source resistors?
also how to measure current if it is loaded with a drain transformer and a source resistor, or with a drain resistor and a source transformer?
Hello neazoi,
If you want to measure the DC current, you can measure the voltage drop across the resistor with a normal multimeter. For measuring the AC current, you need a oscilloskop or a multimeter, which can measure the AC voltage across the resitor.
Regards
Rainer
Reactions: neazoi
    neazoi
Hello neazoi,
Regards
Rainer
The datasheet states a 10mA current through the transistor to achieve the lowest noise. I think this is DC current right?
But which resistor, the drain or the source one?
If you can explain me why you assume drain and source current of a MOSFET to be different, I'll try to answer the question.
Reactions: neazoi
    neazoi
Ok, so it does not matter where to measure it.
Is it DC current I have to measure?
