isurunalaka
Member level 5
hi, does anyone know a method to measure coating thickness of small metal springs?
capacitive measurement.
Where the coating acts as dielectric material. The thicker the coating, the thicker the dielectric, the more the distance between electrodes, the smaller the capacitance.
i also can imagine eddy current.
Klaus
i know that there are tools for measuring paint finish at cars to check if the car had an accident.
But sorry i caonßt recommend a tool.
Klaus
A destructive test procedure may be easier.
1. Cut the spring and take a single turn coil (looks like a helical spring lock washer).
2. By using a small vice press the single turn coil at its cutting side, so that helicalness disappears.
3. Measure the diameter of the coated spring wire by a digital micrometer screw gauge.
4. Take out the coating (by using emery paper or chemical or other way) and measure the diameter of the uncoated spring wire.
5. Coating thickness = [diameter(coated) - diameter(uncoated)] / 2
Digital micrometer screw gauges with 1um (0.001mm) resolution are easily available.
ebay link: **broken link removed**
