grendhell
Member level 1
I've found many post on this topic but none of them cleared all my doubts.
I want to measure the gain of one antenna using a VNA and a standard horn antenna (with gain data-sheet).
The idea is to use Friis formula in this way:
1) Pr = P0 Gt Gr λ^2 / (4πR)^2
where Pr is the power received, P0 is the power accepted by the TX antenna, Gt is the gain of the TX antenna (a standard gain horn) and Gr the gain of the RX antenna (the unknown gain antenna). In dB terms, Friis formula can be written as:
2) GTX + GRX = 20log(λ / (4πR)) - 10log(P0/Pr)
where GTX and GRX are the gains expressed in dB of the TX and RX antennas respectively.
The unknown variables are GRX (GTX is given in the standard gain horn data-sheet), P0 and Pr. Can I use the VNA to calculate P0 and Pr as
3) P0 = 1 - abs(S11)^2
4) Pr = abs(S21)^2
and therefore measure GRX using equation (2)?
If not, could you please explain me why and suggest a different setup/method with the available equipment?
cheers
4) Pr = abs(S21)^2
cheers
