Piet de Pad
Junior Member level 3
Dear Reader,
I recently simulated the circuit shown below using MultiSim and obtained some interesting results.
The simulation suggests that you can accurately reproduce the AC line voltage from the input to the output. Given that optocouplers are typically not linear, this outcome is surprising to me.
Has anyone else conducted a similar experiment or observed this on an oscilloscope? I looked at the Spice model and saw various sub. models used to make the Opto model. To me, it looked as a normal diode transtor modeling. Could the result be due to the simulation model of the ptocoupler used by the simulator (SPICE)?
I look forward to your responses why this simulation is within margins of what you can expect or that this simulation way of from reality. Two heads are better than one.
Regards,
Regards,
