dohzer
Member level 1
![Member level 1](/styles/images/ranks/dlevel1.gif)
I've got a device I need to connect to multiple power supplies and a controller for testing. The device has several modules that all operate off different voltages (12V, 24V and 48V).
The device under test (DUT) has a housing that is used as a common ground point, with all the supplies and controllers connected to it in a star ground configuration via cables (red supply and black ground lines on the diagram).
External to the DUT I need to measure the supply voltages and currents (orange and pink lines on the diagram).
I don't want to create ground loops, so I'm thinking I will need to use differential measurements for each voltage/current signal.
The current measurements will be taken across a shunt resistor.
I have differential ADCs in the controller.
I'm a little overwhelmed with the number of different op-amps and configurations I could use.
What would be the best configuration for this setup?
General setup:
![Differential Measurements.jpg Differential Measurements.jpg](https://www.edaboard.com/data/attachments/52/52701-818a60e5f2dcd102ec5d716b24ab8245.jpg)
General purpose op-amps setup differentially, fully differential op-amps, instrumentation amplifiers.
Single-ended measurement to differential ADC input.
Differential measurement to single ended ADC (negative ADC input grounded).
Differential measurement to differential ADC input?
General setup:
