Measure Movment in 45 degree ?
bobcat1
Hello
I need to measure the movement {speed,distance} of an object traveling from point A to Point B
the object loceted on a rod with 45 degree of inclination
Any suggestion how to mesure ?.
Thanks
Bobi
From my Idea, I think.
If not too long length you may use magnetic field measurement, hall, MR.
If long length you may use Ir or RF connection.
Good Luck
