http://www.vishay.com/docs/83802/83802.pdf
http://www.analog.com/UploadedFiles/Data_Sheets/597695969332879224376031AD8221_a.pdf
http://www.onsemi.com/pub/Collateral/NTS4001N-D.PDF
http://www.fairchildsemi.com/ds/FC%2FFCD5N60.pdf
FvM said:You're using a HV FET, I would expect several 100 V, far above AD8221 common mode range.
FvM said:I understood, that you wanted to include the differential amp in the final circuit as a gate-voltage feedback. That's no completely impossible, but to my opinion, you reached the point where to consider an alternative gate-drive technique, e. q. using a transformer for energy transfer.
FvM said:As the required gate charge respectively ton depends on off-state Uds, the hightest operating voltage should be applied to the switch when determining ton.
FvM said:he testec differential probe isn't very expensive,
http://www.ohmcraft.com/Resources/02_Data_Sheets/DS_HVD_HighVoltageLeadedResistorDividers.pdf
http://artikel-software.com/file/instrumentation%20amplifier%20handbook.pdf
http://www.analog.com/UploadedFiles/Data_Sheets/AD202_204.pdf
http://media.digikey.com/pdf/Data%20Sheets/Analog%20Devices%20PDFs/AD210.pdf
Sinisa said:You can use another low cost opamp with sufficient specs ...
I understand this as a suggestion to use either a floating or isolated supply for the buffer, otherwise the divider would make no sense. I recently also mentioned a solution with a floating supply:You can use another low cost opamp with sufficient specs as a buffer for Vgs signal and feed it to resistor divider.
Both variants have restrictions and couldn't be regarded as general purpose differential probes. I can report, that most engineers in a lab are using resistive divider differential probes as the said Testec, Tek or similar with 5-10 Mohms input resistance for differential measurements, not only for power electronics, the intended main application.Finally, if the switch circuit (apart from gate net) hasn't that high impedance, a buffer may also be supplied from current sources (respectively resistors) and Z-diodes. The buffer output can be coupled as current signal across the common mode voltage. This technique is often used for high side current sense circuits.
max0412 said:This looks like it would be perfect with the exception of the low input voltage spec +/-5V. Is there a way around this or another IA that can except differential voltages to 14-15V? In the same price range as the AD202 $50.00.
I see the AD210 fits the bill but at almost twice the price.
