Measure DC current of a motor using an Arduino nano
abouabdelmajid
Newbie level 5
Newbie level 5
i am trying to mesure the curent of a 12v DC motor using an arduino nano. i used this diagram
i used this code
Code C - [expand]
8
9
10
11
12
13
14
void setup() {
Serial.begin(9600);
void loop() {
float average = 0;
for(int i = 0; i < 1000; i++) {
average = average + (.044 * analogRead(A0) -3.78) / 1000;
//5A mode, if 20A or 30A mode, need to modify this formula to
//(.19 * analogRead(A0) -25) for 20A mode and
//(.044 * analogRead(A0) -3.78) for 30A mode
delay(1);
Serial.println(average);
instead of having the right value 12.92ma (measured by amperemeter) i am havung wrong negative values
Somebody can help me please
Sadly, I think we can't help.
* We don't know the measurement range of your system (to calculate the multiplier. In your case: 0.044A/LSB)
* and we don't know the zero_current_offset of your system. (to calculate the subtractor. In your case: 3.78A)
Klaus
Hello,
Datasheet of your sensor ?
if it is an ACS712 , offset is arround VCC/2
and with a scale of 30Amps, no chance to measure 12.92 mAmps !
Event with a scale of 5Amps..
This kind of sensor dose'nt cover all the scale
ie: for 5 Amps scale AC712 sensor
you have 185mV/Amps so with ADC10 bits 5V => 37.88 points / amps
so +-512 poinst => +-13.5 Amps for +-2,5V,
it is not fo +-2,5Amps!
